Andrey Pyntikov (dekry)
0 answers · asked · Lesson: Object Constraints: Limit & Copy · Course: Fundamentals of Rigging in Blender 2.7
So it seems like ["Limit Location constraint" + parenting] yields the same effect as ["Copy Location constraint"] given th...
So it seems like ["Limit Location constraint" + parenting] yields the same effect as ["Copy Location constraint"] given that they are restricted on the same axis. Which setup is better to use? If its situational, when would it be better to use parenting+limit constraint and when would it be better to use a copy constraint?
