zjjt
1 answer · asked · Lesson: Array Modifier · Course: Modeling with Modifiers
hi there i had troubles with the size and scale of each following steps in the array and i did alt+s to reset the scale of...
hi there i had troubles with the size and scale of each following steps in the array and i did alt+s to reset the scale of my cube object which i had scaled in object mode on the y axis to get that rectangular shape.So what do you advise? should i make transforms only in edit mode if i want to scale/rotate the mesh data in order to not mess up the applied modifiers?
