Hi guys! https://i.imgur.com/9MsRnKf.jpg So I'm trying to model this purple element using Mirror and Array modifier ...
Hi guys!
So I'm trying to model this purple element using Mirror and Array modifier but when I try to apply Subsurface Subdiv after, it seems as the verices on the open ends of the model are "splitting". I have "merge" checked in Mirror and Array mod. and the order of the modifiers is (from the top) Mirror/Array/Surf-Subdiv. Dont really know what am I doing wrong here.
Mateusz Wawrejko (matblack)OK I figured it out. My basic piece of the mesh was a bit off so that it overlapped the neighbours. Even trying to fix it with distance threshold wouldn't work because it was messing up the rest of the mesh. Had to model it again but now it works perfectly. Just letting you know, maybe someone will have similar problem. Cheers
Thanks for sharing your solution!
