Ar (arianakido)
1 answer · asked · Lesson: Subdivision Surface Modifier · Course: Modeling with Modifiers
Would be accurate to use the following method do make realistic edges?: First, applying the Mean Crease to the edges, and ...
Would be accurate to use the following method do make realistic edges?: First, applying the Mean Crease to the edges, and then (instead of the said in the video) applying a Bevel to round the edges a bit, obtaining the same result, just a little doubt, about what is better, regards
