kesey
4 answers · asked · Lesson: Blocking the Major Forms · Course: Modeling a Post Apocalyptic Vehicle
No texturing or materials?
    Not in this course, but you can check out the Fundamental courses as a part of the Intro to Blender learning flow for texturing and material lessons: https://cgcookie.com/flow/introduction-to-blender/
  • No worries, just wondering. I signed up for CG Cookie specifically for this car tutorial so I was hoping it would be more involved. Would you be able to help with a couple things one on one via teamviewer or skype? I'm not making the same type of vehicle, nor am I using the block method. I'm running into a couple problem areas though, my vehicle is much more rounded. It's a 1979 Baja Bug to be specific.
    I'm not able to help on Skype/Teamviewer but if you start a thread on the community forums then I'll be happy to try and chime in, as will many of the other community members: http://community.cgcookie.com
  • I ended up following your old 911 tutorial, much more what I'm after. The extrusion by extrusion, manual edge flow is more what I was after. I will post if I need help. Thanks.
