I have an issue with the toe curling action? For some reason, I have to scale up the larger CTRL bone massively to get the...
I have an issue with the toe curling action? For some reason, I have to scale up the larger CTRL bone massively to get the smaller toe bone to curl after applying the action. Any ideas?
Kent Trammell (theluthier)Hmm..I'm not sure off the top of my head. You're welcome to submit an Intercom ticket with you .blend file and I can take a closer look if you'd like.
Kent, thank you for the reply! I managed to get it to work, I needed to have the Action "From Target" set to local space in the end. Not sure what the difference is but it works perfectly now. Hopefully this won't cause any issues further down the line. By the way, Thank you for creating this fantastic series! I've learnt more on this than I ever have before!
