yishi
1 answer · asked · Lesson: Intro to the Sculpt Tools UI Addon · Course: Modeling a Sci-Fi Helmet in Blender
Hi Kent, I'm using grease cut but it's not working correct. It either deletes the whole piece or cut it successfully but l...
Hi Kent, I'm using grease cut but it's not working correct. It either deletes the whole piece or cut it successfully but leave the mass hollow inside. I tried your suggestion on closing the stroke still not doesn't work. Do you know any way to fix the problem? I'm stuck right now since so many pieces in the video are created by grease cut. Thank you!
