resin213
1 answer · asked · Lesson: Spot Lights · Course: Fundamentals of Lighting
Also, if I don't have the light selected it disappears from view and I can only select it from the hierarchy window, it a...
Also, if I don't have the light selected it disappears from view and I can only select it from the hierarchy window, it also seems much smaller compared to the one in the video, yet my car scale is 1,1,1. I'm not sure what is going on or if it something to do with the way my scene is set up.
    It's hard to understand what's going on in your scene. I'd recommend testing this out in a new scene. The scale of the light won't really do anything. If you want to adjust the intensity or range of the light it'll all be done within the light component.
