When I selected cube to try unwrapping with follow active face I obtain No active face error
Marco Modena (mamo)solved
What did you have to do to solve it?
Had the same problem. Changed from "vertex select" the "face select" and selected all. Then I code an active face (dotted).
I had all cube's faces selected I had to deselected one face and reselect it. Ps. Sorry the late answer
Ran into the same problem. Your tip worked. Thanks.
