This isn't working for me. I can see you're in object mode when you paint, but when I'm in object mode, I don't see the ou...
This isn't working for me. I can see you're in object mode when you paint, but when I'm in object mode, I don't see the outline of the UV map in the UV editor, whether or not I have to object selected in the 3d view. If I'm in edit mode I can see the UV outline in the 2D editor, but my paint doesn't appear on the model whether or not I have anything/everything selected in the 3D editor. I've been following along exactly up to this point so I don't know what is different that's making it suddenly not work. As far as I can see from the video, all my settings are exactly the same as yours. I'm using 2.75.
Kent Trammell (theluthier)So you're not able to paint on your model at all? Have you tried following along again just in case you missed something?
Ok, I figured out what happened. I somehow made two separate texture files, and I was painting on one that wasn't... I don't know what the terminology is. It wasn't linked to the mesh.
