Is it worth mentioning Tile Size as related to your redering options, ie CPU or GPU? there was an article on another site ...
Is it worth mentioning Tile Size as related to your redering options, ie CPU or GPU? there was an article on another site (which i can't find, typically) that had a full range of tests and GPUs were faster w/ larger tiles whereas CPUs appeared to prefer smaller tiles. using these sizes reversed would increase your render times.
cheers
KW
status451_cgI think that is a good point, together with the Auto Tile Size Add-In (included in Blender) that when enabled will adjust the tiles to optimum sizes when switching between CPU and GPU rendering. I find that really useful.
ah, i didn't even know about that! thanks for the info!
I believe this is the article: https://www.blenderguru.com/articles/4-easy-ways-to-speed-up-cycles/
