Tim Brennan (beetle)
1 answer · asked · Lesson: Shared Mesh Data · Course: Mesh Modeling Fundamentals
Can you define what you mean by "destructive workflow" and why it should be avoided? Thanks
    A "destructive workflow" means that the changes you make are permanent, in the sense that you can't modify them later without just undoing everything. A non-destructive workflow is very powerful because it enables you make changes at any point. For example, using the Subdivide operator in Edit Mode with the smoothing option to round out a mesh is a very destructive operation. It's committing the changes permanently to the mesh. On the other hand, using a Subdivision Surface modifier is non-destructive because you can change the number of subdivisions at anytime without ever committing the changes. Make sense?
