macpearl
1 answer · asked · Lesson: Object VS Mesh Data · Course: Mesh Modeling Fundamentals
If I create a model, how can I save that model to export to another software in a specific format?
  • when your model is done, select it. Then go to : File > Export and chose an export format You can then browse through your system to chose where you want to export. On that same windows, on the left, you should activate the checkbox "selection only" then in the top right corner clic on export and you're done. ;)
