Richard Pike (richardrichard)
1 answer · asked · Lesson: Loop Cut & Slide · Course: Mesh Modeling Fundamentals
Going back to the double loop cut on the cube. If you extrude then scale in - what happens to the faces that were extrud...
Going back to the double loop cut on the cube. If you extrude then scale in - what happens to the faces that were extruded over? Do they vanish or become zero area faces? (Or something else?)
