Ben (bendavidconwayme-com)
2 answers · asked · Lesson: Next Steps in Blender · Course: Blender Basics Course
What is the hot key he's using to bring up those shortcuts in the 3d viewport? Can't find it in the manual, and not mentio...
What is the hot key he's using to bring up those shortcuts in the 3d viewport? Can't find it in the manual, and not mentioned in this video..
  • Not sure which hotkey you are referring to but if you open the "user interface", under the "input" tab you'll be able to do keyword search for hotkeys and reassign them should you need to. There is also this wiki article for v2.4 but I presume most of the info is still accurate for v.2.7 https://wiki.blender.org/index.php/Doc:2.4/Reference/Hotkeys/All There is also PDF cheatsheets available online if you look for them. Have fun!
    At which point in the video are you asking about? If it's the ADD menu you're wondering about then it's SHIFT+A.
