Its ok to submit the excercise in the latest Blender version (2.77)? Also, i sometimes saw Mr Jonathan changing the mesh s...
Its ok to submit the excercise in the latest Blender version (2.77)? Also, i sometimes saw Mr Jonathan changing the mesh selection mode without using the buttons in the bottom.. I know it can be done with CTRL-TAB, but that opens a small menu too and i dont see it either. Is there another, more direct hotkey to switch to verts/edges/faces?
Jonathan Williamson (jonathanwilliamson)Absolutely! In most all cases I always recommend using the latest version of Blender. As for switching modes, you can just press Tab to toggle between Edit and Object mode.
Sorry, my question was bad... what i was asking was "inside Edit mode"... a hotkey to switch from verts to edges or faces mode, or viceversa...
http://blenderartists.org/forum/showthread.php?359694-How-to-assign-hotkeys-to-quot-Vertex-select-quot-quot-Edge-select-quot-and-quot-Face-select-quot
thanks monk, gonna try that :)
