I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows...
I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows on a Macbook Pro the "end" key is changed to function + right arrow. However, I cannot get it to close the window.
Jonathan Williamson (jonathanwilliamson)Hey Nicolas, which window is that? Is it the user preferences? You should be able to close any separate window via the Red X at top right. If you're trying to merge two windows together then right click on the divider and choose "Merge".
No, I think he means he is working on a Macbook and to close and open Tools you use 'T', however to close and open the right hand Transform Tools, on a Windows you use 'End' but what is the key for this on a Macbook? (I'm having the same problem)
Oh. The key to open the viewport properties on Mac and Windows is the "N" key. I can see how that could easily be mistaken for "End".
