Kornei Sgibnev (korneisgibnev098)
1 reply · posted
Shrinkwrap Modifire
Hello Everyone! I've got a problem with shrink-wrap modifier. When it's on the position of tire details is incorrect. What do I need to do? 😅
  • You mean that it's not visible but sticking through the tire? Under mode you have selected 'on surface'. I believe there's also an option 'above surface', which prevents it from sticking through , and then maybe you have to  turn up the 'offset' value a little bit.
    Maybe you should play with the other mode option too to get the result you want (I believe there's an option called 'project' which might work better).
