mailmetothemoon
2 replies · posted
How to separate coins for use with rigid body physics?
My coins are made of two objects with two materials (gem embedded coins) I've combined them. Then I set up the arrays, and all that worked well, but when it came time to separate them with the P command, it slices them all apart. The gems fall off, etc.
What can I do to fix this?
  • Interesting problem...
    You will need to make the coin and gem into one Object. There are at least two ways to do this:
    Use CTRL+J to combine the gem with the coin. Then you SHIFT+D and move it followed by SHIFT+R several times to make more cons. You'd have a selection problem if you would have used an Array Modifier with this method....
    The other way is to take the coin and use a Boolean Modifier to connect the gem to the Coin. Then Apply the Modifier and then make the two materials and delete the original gem. Now use the Array Modifier method.
  • I'll have to try the boolean modifier next time! I think that's what I needed!Thanks!
    What I ended up doing is your first suggestion, where I just joined them and duplicated them by hand.
    Turned out well in the end!
    https://sketchfab.com/3d-models/firstchest-2013b21f7b54406fbecc072de47e8be8
