sageart
9 answers · asked · Lesson: Object VS Mesh Data · Course: Mesh Modeling Fundamentals
data PROBLEM in blender 2.8
Hi, i tried linking many objects to one source objects,
it worked using ctrl L..
but the other objects rotates to match the rotation of the original source object
How can i prevent this
thanks
    Hi ssageart ,
    Did you apply the rotation (CTRL + A > Rotation) to all the objects?
    There are  very rare occasions when you want to apply the rotation or location. The scale is the only one you want to apply.
    • thanks for the reply
      yes i did
      i even applied all the loc,rot and scale but they keep rotating to the original object
      You shouldn’t apply the rotation and location hardly ever.
    • ssageart exactly, that is what adrian2301 is saying: do not Apply the Rotation (or the Location)!
      Here's two Cubes, rotated differently (in Object Mode!):
      Look at the Position of the Vertices!
      Now see what happens when you Apply the Rotation of both:
      And then Link the Object Data (the Position of the Vertices get 'Linked', i.e: become the same):
      It is a confusing thing to grasp, at first (and hard to explain), but you will need to understand this and you will, with time!
    • so in short, applying their rotation will make them rotate to the source object
      Understood
      Correct and applying the location they will jump to the same location as the source object
    • i know this is weird but is there any way to undo apply rotation?
    • is there any way to undo apply rotation?
      ssageart apart from CTRL+Z, no.!
      That is why it is important to not Apply the Rotation, unless you have a good reason to do so.
      Look at it this way:
      Any Object has an Origin, that shows as an orange dot, but is in fact a 'personal' Coordinate system for that Object, with an  X-, Y- and Z- axis. When you rotate an Object in Object Mode, You are actually rotating the Object Origin's axes. And if you then scale on the (local) Y- axis by 2, for instance, the Object Data (where are the Vertices of this Object) doesn't change, but a step in the Y direction will be twice as long as a step int the X-, or Z- direction:
      well, there are a few ways actually, but they are close to a nightmare and really not beginner's friendly ;)
