Tristan (tristomenace)
1 answer · asked @ video mark 10:48 · Lesson: Unwrapping a Low Poly Ax · Course: Fundamentals of Texturing in Blender
Speed up the alignment of vertices in the UV editor
Fun little trick: while in the UV editor you can select all the vertices belonging to the islands you want to align/stack and hit M (Merge) > By distance and adjust the threshold — just like you do in the 3D viewport. Much quicker than individually snapping vertices on top of each other.
I'm not sure which version this was introduced in, but it's available in 2.92.0
