Having some trouble with the bevel and inset step in 2.9
Whenever I bevel the windows, I end up with a structure like this, which I think is correct
However if I try and inset afterwards there are some faces still hanging around. It seems to happen regardless of whether I'm in face select or edge select mode. Not sure how to get around this.
Hey ggreenestbanana ,
You said you bevelled the edges before extruding. You should be selecting the face where you want your window and Inset with I , not bevel, then extrude with E.
Hope this helps.
It is also possible that you've got some 'double vertices'.
Select all in Edit Mode with A and then M > Merge by Distance (before Inset).
I would up doing the bevel, deselecting the non-bevel faces, and extruding individual which seemed to work. I will try those other suggestions next time.
