can't set color to frame
I am trying to give my frame a color like you do (11.23sec) but all I get is a standard Line....
Any advice or idea what that could be?
Thank you very much
Martin
Kent Trammell (theluthier)
Make sure you have the Color box checked?
Indeed it is
also in the Preferences I couldn't find anything wrong 😪
It must be a theme setting then. Check in your User Preferences > Theme > Node Editor > Frame Node
Make sure the A (alpha) setting is not set to 0. If it is it means it will always be 100% transparent. The default alpha value is 0.8.
God bless you Sir!!!
thank you!
