Grid Fill multiple areas
Hey there just wondering if there’s a way to grid fill multiple edge areas at the same time, ie in this rough example I know I can grid fill these selected edges…
but can I grid fill all these edges at the same time rather than having to do a second grid fill operation…
The reason I ask is because I may have a lot of grid filling to do.
Thanks in advance.
You can only fill one area at a time, Blender will either shout error or think it is one big space to grid fill and you won't get the result you are looking for.
I think Blender might have an issue trying to grid fill a big area that is not relatively flat. You maybe better of with the F2 add-on, its free with blender, you just need to enable it in the preferences.
Go to Edit>Preferences click Add-ons and in the search type F2 and enable the add-on.
It works by creating faces based on one edge and when you press f it will create a face in the direction of your cursor press f again and it will create another face without the need to keep selecting edges or verts.
You will need to add some more geometry first though. You have a very strange shape to fill.
Can you give a clue as to what the final shape should be??
I can't see a way of filling this shape without issues unless I know what you are trying to achieve.
