Victor Panggabean (vpanggabean1980)
5 answers · asked · Lesson: 3D Print Resin · Course: Shader Forge
Using RGB for subscatter radius
Hi theluthier
What do you think of using rgb for the subscatter radius for easy tweaking.. is it correct? because i notice the output and input color socket is different.
Also can you tell me why didn't you put the cavity (pointiness+colorramp) to the factor input of the mix rgb?
if i understand correctly the cavity is some kind of a mask? so i thought that it is suitable to plug it in the factor input.
And also is the course for learning the absorption node group is still available?
Thanks
    It's OK to use RGB (yellow socket) output for vector (purple socket) input. The XYZ vector data simply uses RGB values. Here you can see that the manual scatter radius values match the RGB values and the visual result is the same:
    spikeyxxx can you verify me on this?
    why didn't you put the cavity (pointiness+colorramp) to the factor input of the mix rgb? if i understand correctly the cavity is some kind of a mask? so i thought that it is suitable to plug it in the factor input.
    You certainly can use a cavity style input (texture or pointiness) as the factor. It all depends on what you want to do with it. Using it as a factor means I want to explicitly choose certain colors for the black and white values in the cavity input.
    However in this case I wanted to use it more subtly. I wanted to keep the mix operation centered around one color: the light blue from the SSS base color value. Essentially I wanted to slightly darken+saturate the blue in the darker areas of the cavity while lightening the blue in the lighter areas of the cavity. Using a black and white input as an overlay on top of the blue color is perfect for this effect. And that leaves open the factor slider for adjusting how strong the overlay effect is.
    There's a myriad of ways to use the mix RGB node. Very powerful! And all dependent on the situation / desired effect.
    It's an old course but the math should remain true with current blender: https://cgcookie.com/lesson/maple-syrup-material
