Is there a benefit of using a Boolean cut with flipped normals on the cutting cube?
Wouldn't it be easier to choose "Difference" as "Boolean Modifier" mode or is there a special benefit of using a Boolean cut with flipped normals on the cutting cube and "Intersection" as the modifiers mode on the duplicated bird?
