chrisjpatty
2 answers · asked · Lesson: Shaping Pieces · Course: Introduction to Character Modeling
How did you change the color of the transparency in Xray mode?
Like yours, my modeling sheet has a white background, so the white faces of transparency mode blend right in. In your video you've somehow inverted that color so you can see it, but after googling around I still can't figure out how to do that.
  • Hi Chris, what version of Blender are you using?
    If it's pre-2.8, you can go to File > User Preferences:
    and increase the Alpha like in above screenshot (by default it's almost 0). This will have this effect:
    You can even change the color if you want.
    Mind you, this is the color for unselected Faces. Slightly below in the left column there is a Face Selected that is still transparant orange, but you can change that also.
    Mind you, I think Jonathan Williamson has a special Theme installed.
    In 2.8+
    You can also use Minimal Dark as Theme, that has darker Faces, but it's good to know where to change it, in case you have other-colored Background Images.
  • Awesome, that's just what I was looking for, thanks!
