Render keyframe number within motion path in Blender 2.8-2.9
I don't have the keyframe number rendered with the motion path using the viewport render animation like most of the recent submissions but I noticed some olders has.
Enabling the keyframe numbers from object/motion paths/display make it visible within the viewport using the camera view, so where is the magic toggle to enable it also when rendering the viewport animation?
Thanks =)
Wayne Dixon (waylow)
Hi Franck.
Just check you have keyframe numbers enabled in the little display toggle menu.
Hope that helps.
Hi Wayne,
Thanks for the answer.
Unfortunately when I enable it via this display menu (in my case from the object properties as I don't use an armature) it's only visible in the viewport editor but not when using viewport rendering.
Same thing happens if I don't render from the camera view using viewport rendering:
I know it doesn't bother for this exercice I just wonder in case it could be for a future one. -
Ah yeah, I see. They must have changed that. I can't recall if it was changed in 2.80 or later.
But I know for sure you could see that numbers in 2.79
It's not a issue though, the main reason you need the numbers is for the animator in the viewport.
Ok Thanks !
