sharkbait1986
2 answers · asked · Lesson: UV Unwrapping pt. I · Course: Modeling Weapons for a First Person Shooter
Apply modifiers?
I assume I should apply the mirror modifiers after I'm done with the seams, or is there something else Im supposed to do?
    You don't have to! You can keep it mirrored while unwrapping, though you may run into some trouble (like I did) while texturing where any text you write on one side will be backwards on the other. If you want to avoid that then yes, now would be a good time to apply it.
  • I figured this would be the case, was a bit confused as the method is a bit different on 2.83 so Kinda had to make sure. thanks for the fast reply! =)
