Coin won't stop bouncing
I'm trying to simulate the coins but I can't get them to stop bouncing which means they won't settle when I have a group of them. I've tried changing the friction and bounciness of both the coins and the collider but regardless of whether they are 0 or 1 they will keep bouncing around. Is there something I'm missing here?
  • I would use Planes set to Box as 'floor' and 'sides' and use a Convex Hull for the coin. In both cases leave the Collision Margin unchecked:
    That should give a more stable result.
    (You have your Margin set really high, which is part of the problem, but simply reducing that won't solve it.)
    I hope this helps you, I am no expert on Blender Physics;)
