shanr
6 answers · asked @ video mark 7:56 · Lesson: Create a Procedural Space Shader in Blender and Generate Billions of Stars
It is just turns pink !
Why when I connect the mix shader to the background it Turns pink. What is the reason?
Here is the node!👇🏼
  • Hi shanr, you are using a Mix Shader instead of a Color > Mix RGB Node! (You can see a red line where you connect the output of the Mix Shader to the Color input of the Background Shader, indicating that the connection is wrong!)
    • Yup. Use Mix RGB instead and it should work better.
      I've done that a time or two.
    • The naming of these two nodes is a bit inconvenient, I think...It took me a few years before I understood the difference and when to use which, (This was before the different types of Nodes had different colors; all the Nodes where grey, which made it a lot less obvious...I can't even look at that any more.)
      A Mix Shader is not just a 'Shader that mixes', but it mixes Shaders. In the same way: a Mix RGB, mixes (RGB) colors.
      I like to think of them as 'Shader Mixer' and 'RGB Mixer'...
      Also an Add Shader is not just a 'Shader that adds', but it adds Shaders together, so more of a 'Shader Adder''...
    • It Worked!
    • Glad you worked it out shanr! Thanks for the great answer spikeyxxx and Shawn.  :-)
    • I like Spikeys word shifts, that helps a bunch on how to remember what they do...
