Can't set proxy for 2.8
After I link the VonnBots... I am not sure how to set proxy, ctrl + alt + p doesn't have any respond. What should I do?
There is no longer a shortcut for that. Go to Object > Relations > Make Proxy.
When you right-click on Make Proxy, you can put this in your Quick Favorites, or add your own shortcut (actually, CTRL+ALT+P is still free..)
Thanks, it work !!!
Hot Tip: if you can't remember where anything is in the menus you can search with F3
and then just type what you are looking for.
F3 > 'proxy' > enter
