curtisdd1
1 answer · asked · Lesson: Revolver Pt. 4 - The Body · Course: Blender Mesh Modeling Bootcamp
Trigger hole -extrude question
Hi, Why did you extrude the trigger hole face twice - once just a little bit then a little more rather than just a larger  extrude upward?
  • Probably to create a holding edge. You could also extrude once and then later add an edge loop with CTRL+B, but when you already know you'll be needing a holding edge there, you might as well do it like this. (This is common practice and you will see people do this all the time.)
