donbonbon
0 replies · posted
Pixelated render with Eevee
My render is way too pixelated.
I note that when I have a Large shot the face and details would be too pixelated on  Eevee and clear only on in close ups.
I don't know how to tackle this issue,  something I find it too distracting.
The only solution I found was render at 400% which isn't ideal solution.  as when I render it with other camera settings the a 100% image side render provide a clear solution. You can find sample in the wasp bot file, which I downloaded from blender.org to test by verified settings.
Attached two files Olivia Olivia disco which is my blend, and pixelated, file and wasp which I downloaded from blender.org as it shows that my meshes could be rendered clearly at 100% if the camera is well set.
I do however need to move the camera, and once I do it, the render becomes pixelated.
This happens to me in several characters, scenes.
I tweaked, all parameters (lights, camera setting, baking, TD, etc').. the results are more or less the same.
I can only assume I miss here something fundamental in my settings, i.e. that I have a major hole in my understanding of blender and rendering... but what am I missing?
any help, advice would be highly appreciated.
