hjoucka
4 answers · asked @ video mark 10:08 · Lesson: Modeling Tentacle Arms · Course: Creating a Jellyfish
I cant apply modifiers/ convert to mesh after choosing the keyframe
when i try to apply the modifiers it gives an error: modifiers cannot be applied to a mesh with shape keys
    I just confirmed that I too cannot apply modifiers on an object with shapekeys. However I am able to convert to mesh to functionally "collapse" the model + modifiers + shapekeys.
    Are you sure the convert to mesh option is giving you this error and not just the apply button in the modifier?
  • Not able to convert to mesh. Convert to mesh option is not on the list. Hot key doesn't work
    • Since 2.8 this particular hotkey has been removed. You can find it here:
      Or use the Search menu.
      If you right click on 'Mesh from Curve/Meta/...'' you can assign a hotkey to it, or you can put it in your Quick Favorites if you are using this often.
    • Yup, got it! Thanks guys
