crew
Kent Trammell (theluthier)
1,434 replies · posted
Collab 2020: Modeling Heavy Equipment (Backhoe)
Accomplishing a BIG project TOGETHER
Starting in March 2020, I began a large stream project to model a comprehensive, highly-detailed Caterpillar 434E backhoe. Please watch the first stream (first 3 minutes of abridged version at least) for an overview.
It's a straight-forward project of building a complex model over an extended period of time. The spin on the project is that I want your help to accomplish it! If I build some parts and you build some parts, we will finish this thing much quicker. Plus the contribution format will include reviews, the potential of having your piece(s) assimilated into the final model. Not to mention large quantities of XP are at stakeΒ πŸ€‘
NOTE: This is an involved project reserved for Citizen members.
Collaboration Details
The general idea is that I kickoff stages of the project via live stream, which is typically once per month. For the time in between streams, you choose a piece of the backhoe and apply what you learned from the stream to that piece. For example, the first stream covered initial block out. So between stream 1 and stream 2, your job is to pick a piece and block it out.
This is the repeating protocol for each Assignment Period (between-streams):
  1. Signing up for pieces of the model. I will be maintaining a Google Sheet to organize piece selection and grading. Following this URL will give you the ability to comment. The sheet is sectioned vertically and color-coordinated with a backhoe image. To sign up for a piece, right click on an empty cell below your desired piece section and click "Comment" (CTRL + ALT + M). Comment your name or username and I will fill it in officially as confirmation.
    Remember that it is OK for multiple people to model the same piece. But lets try to have at least one person assigned to each piece before doubling up.
    2. Project file structure. We're going to use Google Drive as a means to sync a single working directory among all contributors. See this thread about details and how to get set up.
    3. Submitting your piece for review. Exactly one week before the next stream is scheduled to be broadcast, your piece is due. In the "Attempt" cell of the spreadsheet, paste a download link to your .blend file via Dropbox, Google Drive, or equivalent hosting service. This will earn you at least 10 XP each week.
    4. Review. On stream I will review each submitted piece and decide which will be assimilated into the master model (in the case of multiple submissions of the same piece). The purpose of the review is to generate feedback for you work and advice for improvement.
    5. Assimilation. If your piece makes the cut and is assimilated into the master model, your name / username will be added to the object in Blender. You will go down in history as a definitive contributor to this epic backhoe model!
    Once the model is completely done, I plan to render a short demo reel showing off the model and crediting all contributors. It should be a rewarding conclusion to all the work we will do!
Assignment Prompts
I will reply to this thread after each stream with a [big] assignment post denoted by a Β πŸ“£ emoji in the title. There I will clarify instructions about each Assignment Period.
Online Resources
Reference Images
Livestreams
This is THE thread
We will centralize our collaborative communication between the streams and this thread. Ask any and all questions pertaining to the Backhoe project here.
