Bhavesh Patel (ryzen7)
3 answers · asked @ video mark 12:49 · Lesson: Modeling the Wheels · Course: Modeling a Post Apocalyptic Vehicle
Bridging the edge loops connect the different vertices and gives weird shape
Hi,
When I try to bridge the edge loop,  instead of connecting nearest vertices,  vertices with little bit more offset are connected. I have also tried to play with twist function from the menu but it does not connect correctly.  Only way to connect the edge loop remains is manually now. But I want to know how to solve this thing? Am I missing anything here.
  • rryzen7 Hi.
    This is happening, because the order of the vertices of the two edge loops is not consistent; one is going clockwise and the other anti-clockwise.
    You could, before connecting them, rotate the inner edge loop 180° around the Y-axis. That should fix it.
    Alternatively, enable the Loop Tools Addon (highly recommended!).
    Then if you go into the Context Menu, or look in the N-Panel under Edit you can Bridge from there, which not only gives you the Twist option, but also a Reverse checkbox.
    With F9 (F6 if you are still using Blender 2.79 or earlier), you can change those:
