Want to try this Exercise?
Check out the about tab below and start learning on CG Cookie today.
Get Started
  • Software:Photoshop CS6  ·
  • Difficulty:Beginner
Rules of the Exercise
  • 1
    Download and open the practice worksheet for this exercise.
  • 2
    Observe and analyze the subject matter. Follow the guides of the instructor notes to paint your own boulder.
  • 3
    Submit your finished work for Grading from the community!
- Overview
  Below is the practice worksheet that you can download! You can find this on the "Downloads" tab under the header image near the top of this exercise! GAC_RockExercise
- Tips
  • REFERENCE. Please use reference and find ones that inspire you.
  • Start with a foundation base coat of color, I would recommend a shade of purple.
  • Be bold when painting on the light and avoid shadow regions.
  • Be Patient. Especially when layering or doing repetition.
- Instructor Notes
  This is a fun exercise since we are working with flat angular shapes, which is easier to show lighting on than rounder objects. You just have to keep in mind the direction of the lighting and if the angle of your shape would receive the light, lay it on! This technique of "painting on the light" is a simple one to create form very quickly and helps teach how to add value without excessive shading or using gradients. When you finish the exercise, remember to submit the result to the "Submissions" tab near the top of this exercise. You can see other submissions alongside your own!
