Loading...
Back to Basics
  • Software:Photoshop CS6  ·
  • Difficulty:Beginner
Rules of the Exercise
  • 1
    Download and open the practice worksheet for this exercise.
  • 2
    Create all 6 forms with the correct light placement as directed by the guide.
  • 3
    Once finished, submit your exercise to be reviewed and looked over under the "Submissions" tab for grading!
- OVERVIEW
  I have been requested many times for a simple exercise that focuses on the basics of adding values to create form and structure. Let's break it down into the simplest of simple exercises. Below are four practices for you to zone in and focus on how to shade values. Use the light box directions as you do your own practice sheet.
  • 1. Outie vs. Innie - To start it off, you can have the same shape but how you shade the lighting, will give the illusion of depth. Really imagine where the light source is coming from and how that would be reflected on the spheres.
  • 2. Edges vs. Curves - When it comes to shading objects. There are two extremes you can focus on and everything else is somewhere in between. The first is hard edges and the different surfaces of an object act as "planes" that will often have high contrast due to the edges. The second is the soft gradient edge that reflects the light gradually over the surface area because there is no distinct falloff where the light creates a high contrast. (ALTHOUGH often metallic or shiny surfaces may gave the look of high contrast due to the reflective nature)
  • 3. Different Light Directions - When you begin to imagine your objects in a 3-Dimensional Space, you you begin to imagine lighting and where to place it more accurately. This is a good practice to imagine adding different lighting on the same object, making you think more actively on how you place your lights and shadows.
  • 4. Enclosed vs. Open - Lastly this focuses on two things: bounce lighting: and the subtle difference in shadow values in an enclosed area.
Below is the practice worksheet that you can download! You can find this on the "Downloads" tab under the header image near the top of this exercise! Exercise_29_PracticeSheet (You can hide the green extra tips and guidelines)
- TIPS
  Work fast, and then refine. Also attempt this exercises with just the simple brush so you can focus less on how you create the values and more on if the values are being placed correctly. A lot of artists also ask me how to make the blending look smooth without it looking blurry or without taking hours with a hard edge brush. The trick is getting a solid mix of both or even try using a textured brush like a chalk brush. Also the biggest tip is: STAY CONSISTENT with your lighting choices. If you add a light, make sure that light source is represented throughout the subject matter. Exercise_29_QuickGuide
- THE GOAL
  To strengthen your fundamental skills of rendering values.This is no use attempting advance techniques if you cannot understand and complete the fundamental basics of value shading to create form and shape! The more you can fully comprehend and realistic reflect value shading, the better your pieces will become, trust me! And you should be able to look at something you did a year ago and be able to correct minor flaws, which are often value shading mistakes! Exercise_29_StepbyStep
- The Community Results
I was pleasantly surprised when I saw how many turned in their own submissions but also how great the quality of many of therm are. Below are three that really stood out to me from fjara, digitd, and plutonka. Thanks again to everyone that tried out this exercise and stay tuned for the next one! Exercise_29_Us When you finish the exercise, remember to submit the result to the "Submissions" tab near the top of this exercise. You can see other submissions alongside your own!
